netDbMgr process failed to allocate an event structure. Event allocation failures indicates the system may be running low on memory.
Check the scalability limit and compare this with the current configurations. Reducing the system configuration may help reclaim memory. Once sufficient system memory is reclaimed, it is recommended that netDbMgr process be restarted for internal state to be fully rebuilt.
Error
Failed to allocate an event structure: %name%
| Name | Type |
| name | String |
